TSCALE command (Express Tools)
Scales texts, mtexts, attributes and attribute definitions.
Method
Select the entities and specify the justification used for scaling.
Options within the command
- Scale
- Allows you to specify a scale factor.
- Height
- Allows you to specify the text height.
