TSCALE command (Express Tools)
Scales texts, mtexts, attributes and attribute definitions.
Method
Select the entities and specify the justification used for scaling.
Options within the command
Scale
Allows you to specify a scale factor.
Height
Allows you to specify the text height.
Related commands
  • ATTDEF command
  • MTEXT command
  • TEXT command
Related information
  • Express tools command overview
