TSPACEINVADERS command (Express Tools)
Creates a selection set of the text entities that have another entity that overlaps it.
Method
Select the entities you want to check for overlapping entities or type all to check the entire drawing. The number of overlapping entities is displayed in the command line.
Options within the command
- Should each text be queried individually?
- Allows you to decide if each text should be queried individually.
- Yes
- All overlapping entities are highlighted one by one. It allows you to choose if you want to add the highlighted entity to the selection set.
- No
- The command ends and creates a selection set.
