UNION command
Performs Boolean union operations on 3D solids and 2D regions.
Icon:
Alias: UNI
Note: In the BricsCAD Lite license level, the command applies to region entities only.
Performs Boolean union operations on 3D solids and 2D regions by adding set of entities to another set to form a single entity.
Note: The resulting entity takes on the properties of the ACIS entity selected first.
Method
Specify the ACIS entities to join into a single entity. The program joins regions and 3D solids into a single entity.
The entities selected:
Result:
Note: You can interrupt the command by pressing the CANCEL button.
