UPDATELAYOUTBLOCK command
Updates an inserted layout block reference.
Updates a layout block reference inserted using the INSERTLAYOUT command according to the source drawing layout changes.
Options within the command
- Select inserted block
- Allows you to select the inserted layout block reference that should be updated.Note: For the block to be updated, the name of the source file must be the one from when the layout was inserted.
