VIEWDETAILSTYLE command
Opens the Drawing explorer dialog box with View Detail Styles selected.
Icon:
Displays the Drawing Explorer dialog box with the View Detail Styles category selected to create and modify view detail styles.
Options within the Edit View Detail Style panel
Identifier
Defines the properties of the view detail identifier.
Text style
Specifies the text style used by the identifier text.
Color
Specifies the color of the identifier.
Height
Specifies the height of the identifier.
Position
Determines where the identifier is located.
Outside boundary
Places the identifier outside the detail’s boundary. No symbol is used.
Outside boundary with leader
Places the identifier outside the detail’s boundary and draws a leader from the parent view to the detail. No symbol is used
On boundary
Places the identifier on the detail’s boundary.
On boundary with leader
Places the identifier on the detail’s boundary and draws a leader from the parent view to the detail.
Symbol
Defines the properties of the symbol.
Symbol
Specifies the look of the symbol.
Color
Specifies the color of the symbol.
Size
Specifies the size of the symbol.
Boundary
Defines the properties of the detail viewport boundary.
Line color
Specifies the color of the boundary line
Linetype
Specifies the line type of the boundary.
Lineweight
Specifies the weight of the boundary line.
Context Menu Options
New
Creates new named view detail styles.
Delete
Erases the named view detail style from the drawing without warning.
Rename
Renames the view detail style.
Select All
Selects all view detail styles definitions.
Invert selection
Deselects the current selection and vice versa.
Set current
Sets the selected view detail style as current.
