VISIBILITYSTATES command
Creates and edits visibility states in the Command line.
Icon:
Creates and edits visibility states via Command line. It also opens the Visibility States panel if it was closed before running the VISIBILITYSTATES command.
Note: BricsCAD visibility states are not compatible with AutoCAD® visibility states. When you open a drawing with BricsCAD parametric blocks in AutoCAD®, they are displayed as they were saved in BricsCAD. However, when such parametric blocks are edited or copied to another drawing in AutoCAD®, all entities in the block become visible.
Options within the command
- New parameter
Creates a new parameter.
Type a name for the parameter (<P>), then press Enter.
- Enter new state for <P>
- Type a name for the new parameter state (<S>).
- Add entities
- Adds entities to the specified state of a parameter.
- Remove entities
- Removes entities from the specified state of a parameter.
- make entities Visible
- Makes entities visible to the specified state of a parameter.
- make entities Invisible
- Makes entities invisible to the specified state of a parameter.
- Select state
- Makes the mentioned state active.
Note:
- <P> is a placeholder for the name of the visibility parameter entered in the previous step.
- <S> is a placeholder for the name of the active visibility state of the parameter <P>. On the screen, the actual names of the parameter and the state will be displayed instead of <P> and <S>.
