VLIDE command
Opens the BricsCAD LISP Advanced Development Environment (BLADE).
Opens the BricsCAD LISP Advanced Development Environment (BLADE) to interactively edit and debug LISP applications. It opens in an external application window, allowing it to remain open while you work on your drawings in BricsCAD®. You can move and resize it with standard application window controls.
