VPORTS command
Creates one or more viewports in model space.
Icon:
Alias: VIEWPORTS, VPORT, VW
Creates one or more viewports in model space and allows you to see more than one view of the same drawing.
Note: To create viewports in paper space, use the MVIEW command.
Options within the command
- Lists the names and x,y coordinates of saved viewports.
- Save
- Saves the current viewport arrangement by name.
- Yes
- Replaces the viewport configuration with a new one.
- No
- Saves the configuration with a different specified name.
- Restore
- Restores a named viewport configuration after entering the name of the configuration to restore.
- Delete
- Erases a named viewport configuration from the drawing.
- Single
- Creates a single viewport of the current viewport, removing all others. This option can be used to return the drawing to its original single-viewport state.
- Join
- Joins two or more viewports to a single viewport after specifying the dominant viewport and the ones to join.
- Create 2 viewports
- Splits the current viewport into two rectangular viewports.
- Horizontal
- Creates two horizontal viewports, one above another.
- Vertical
- Creates two vertical viewports, one beside another.
- Create 3 viewports
- Splits the current viewport into three rectangular viewports.
- Horizontal
- Creates three horizontal viewports, one above another.
- Vertical
- Creates three vertical viewports, one beside another.
- Above
- Creates a single wide viewport above two side-by-side viewports.
- Below
- Creates two side-by-side viewports above one wide viewport.
- Left
- Creates one tall viewport to the left of two stacked viewports.
- Right
- Creates one tall viewport to the right of two stacked viewports.
- Create 4 viewports
- Splits the current viewport into four rectangular viewports.
Note: Viewports can be resized by dragging their borders.
