-WBLOCK command
Saves blocks and other drawing entities to DWG/DXF files.
Saves blocks and other drawing entities through the Save Block dialog box.
Options within the command
Block to save as WBlock
Specifies name of the block to write to a file.
Select entities
Selects entities to write to the file on disk.
Insertion point
Specifies the origin point of the drawing.
Select entities
Specifies the entities to create a block.
Note: The selected entities are deleted from the current drawing. To restore them, use the OOPS command.
Annotative
Saves the block as an annotative block.
& to include multiple blocks
Saves multiple blocks from this drawing to the file on disk.
Note: The definitions are saved to the new drawing.
* for whole drawing
Saves the whole drawing, equivalent to SAVEAS command.
