WORKPLANELINK command (Experimental)
Links 2D entities with a Work Plane.
Alias: LINKWORKPLANE
Disclaimer
Work Plane is an experimental feature which may not yet be stable, and could be removed in the future. Use the MANAGEEXPERIMENTALFEATURES command to enable or disable experimental features.
The Experimental mode is disabled by default. Enabling or disabling the Experimental mode requires a restart of BricsCAD®.
Method
Select the sketch (2D entities) and the desired Work Plane that is available in the same spatial orientation to create a link. It creates an association between the sketch and the selected Work Plane to maintain their spatial relationship, allowing for consistent positioning and dynamic updates when parameters change.
Note: The entities must lie on the same plane and remain in the same spatial orientation.
Options within the command
- Name
- Enter the name of the Work Plane.
