XDATA command (Express Tools)
Attaches extended entity data (xdata) to a selected entity.
Icon:
Method
- Select an entity.
- Enter an application name. This will be the application ID.
Note: Use the XDLIST command to view the xdata attached to entities.
Options within the command
- 3Real
- Allows you to specify 3 real numbers (group code 1010).
- DIR
- Allows you to specify a 3D World direction (group code 1013).
- DISP
- Allows you to specify a 3D World displacement (group code 1012).
- DIST
- Allows you to enter a distance (group code 1041).
- Hand
- Allows you to specify an entity handle (group code 1005).
- Int
- Allows you to specify a 16-bit integer (group code 1070).
- LAyer
- Allows you to specify a layer name (group code 1003).
- LOng
- Allows you to specify a 32-bit integer (group code 1071).
- Pos
- Allows you to specify a 3D World space position (group code 1011).
- Real
- Allows you to specify a real number (group code 1040).
- SCale
- Allows you to specify a scale factor (group code 1042).
- STr
- Allows you to specify an ASCII string (group code 1000).
- Exit
- Ends the XDATA command.
