XLINE command
Draws a construction line of infinite length, in both directions, from start point.
Icon:
Alias: INFLINE, XL
Method
Specify a point on the line, then specify the direction of the construction line.
- Point along line
- Direction
Options within the command
- Set point along line
- Allows you to begin creating an xline by specifying a point on the xline.
- Direction
- Specifies the direction of the xline from the starting point.Note: You can continue adding unlimited xlines until you press Enter key to end the command.
- Horizontal
- Creates an xline parallel to the x-axis.
- Vertical
- Creates an xline parallel to the y-axis.
- Angle
- Creates a xline based on a specified angle.
- Location
- Angle
- Xline
- Reference
- Specifies the angle to place the xline relative to the selected entity.
- Location
- Reference entity
- Angle
- Xline
- Location
- Specifies the starting point of the horizontal, vertical, or angle xline.
- Bisect
- Creates an xline which bisects two imaginary lines.
- Vertex point
- Bisection angle start point
- Bisection angle end point
- Set vertex point
- Specifies a point at the vertex of the two imaginary lines.
- Entity
- Allows you to select a line, arc or polyline segment to bisect.
When you select a line or polyline segment, the command draws the xline perpendicular to the segment’s midpoint. When you select an arc or polyarc, the command draws the xline perpendicular to the arc’s center and midpoint.
Note: This option works with splined polylines, but not with spline entities.
- Perpendicular to line's midpoint
- Perpendicular to arc's centerpoint
- Perpendicular to arc's midpoint
- Xline
- Parallel
- Creates an xline parallel to a line or polyline segment.
- Set offset distance for parallel infinite line
- Specifies the offset distance for the xline.
- Select entity for parallel infinite line
- Allows you to select a line or polyline segment from which to offset the xline.
- Side for parallel infinite line
- Specifies the side on which to place the xline.
- Line segment
- Offset distance
- Xline
- Through point
- Allows you to specify a point through which to draw the xline.
- Through point
- Line segment
- Xline
