Compatibility between Communicator for BricsCAD and BricsCAD
Communicator for BricsCAD works with a BricsCAD Pro license or higher.
About
Starting with V26, the minor versions of BricsCAD and Communicator for BricsCAD should match when available (for example, the Communicator for BricsCAD V26.2.x works with the BricsCAD V26.2.x).
Note: Up to V21, the minor versions of BricsCAD and the Communicator for BricsCAD should also match.
Starting with V21 to V25, only the major versions of BricsCAD and Communicator for BricsCAD need to match (for example, Communicator for BricsCAD V21 works with BricsCAD V21).
Note: The compatibility between Communicator for BricsCAD and BricsCAD is always mentioned in Release Notes for Communicator for BricsCAD, under Versioning. The Release Notes for Communicator for BricsCAD are available from the download page.
We strongly recommend using the latest product version of the major version number.
