Add Property dialog box
Opens via: Text Content Editor dialog box
The Add Property dialog box allows you to add properties to text contents for label styles.
- Use property from other objects
- Object type
- Object name
- Select property
Toggle this option if you want to add properties from other Civil objects to this Label Style.
Object type
Select the object type from which you want to select the property. Properties can be added from Surfaces, Horizontal Alignments, Vertical Alignments, Civil Points, Common Lines, Common Curves, Section Views, or Section Lines.
Object name
Displays the object name.
Select property
Select the property you wish to include in the Label Style. It is possible to include the following properties:
From Surface:
Surface Name
Surface Description
Surface Elevation
Surface Northing
Surface Easting
Surface Grid Northing
Surface Grid Easting
Surface Latitude
Surface Longitude
Surface Slope
Surface Slope Distance
Surface Slope Horizontal Distance
Surface Slope Depth
Surface Elevation First Point
Surface Elevation Seconds Point
From Horizontal Alignment:
Alignment Name
Alignment Description
Alignment Station Value
Alignment Offset Value
From Vertical Alignment:
Vertical Alignment Name
Vertical Alignment Description
From Civil Point:
Point Name
Point Raw Description
Point Easting
Point Northing
Point Elevation
Point Full Description
Point Number
*User-defined attribute for Civil Point*
From Common Line:
- Grade Check
- Overall Length
- Overall Length 2D
- Overall Area
- Overall Delta Z
- Segment Length
- Segment Length 2D
- Segment Direction
- Segment Start X
- Segment Start Y
- Segment Start Z
- Segment End X
- Segment End Y
- Segment End Z
- Segment Grade
- Segment Delta Z
- Cumulative Segment Length
- Cumulative Length
- Label Tag Number
From Common Curve:
In addition to the Common Line properties, there are:
- Segment Total Angle
- Segment Start Direction
- Segment End Direction
- Segment Curve Chord Length
- Segment Curve Chord Direction
- Segment Curve External Tangent
- Segment Curve Radius
- Segment Curve Center X
- Segment Curve Center Y
- Label Tag Number
From Section View:
- Section View Name
- Parent Alignment
- Section View Station
- Section View Line Name
- Section View Point Offset
- Section View Point Elevation
- Section View Slope Start And End Point
- Section View Elevation Difference
- Section View Distance
- Section View Offset Distance
From Section Line:
- Section Line Name
- Parent Alignment
- Section Line Station
- Section Line Group
