Add quad button filter dialog box
Opens via: Edit Quad Button Filter dialog box
The Add quad button filter dialog box allows you to select a filter for the quad button (see the Customizing the Quad article).
- Selection drop-down list with filters.
Selection drop down list with filters
The list contains three general filters that apply to any object type.
| NO_SELECTION | The tool is displayed when nothing is selected. |
| OBJECT_ANY | The tool is displayed when one entity (regardless its type) is selected. |
| OBJECTS_ANY | The tool is displayed when many entities (regardless their type) are selected. |
Note: It is possible to type in a custom filter, however it is recommended to use the Add Entity Alias dialog box to create a custom filter.
Note: The custom filter format consists of one of the three general filters with object type suffix like _LINE, _CIRCLE, etc. For example: OBJECT_CIRCLE, OBJECTS_SURFACE_EDGE, etc.
