Add rule dialog box
Opens via: Interference Manager panel > Filter option > Add rule button
The Add rule dialog box allows you to add properties for filtering a selection set.
- Search bar
- List of properties
- Search bar
- Allows you to search by a property name or by a character string.
- Lists all properties of the entities, grouped into categories.
- Filtered property list
- Pinned properties
- Lists only properties that match the characters in the search bar.
Click the property name to set the filter conditions, which depend on the property type.
Note: A property can be pinned for later quick access.
- Pinned properties
- Lists all pinned properties.
