Annotation Object Scale dialog box
Opens via: OBJECTSCALE command
The Annotation Object Scale dialog box allows you to add or remove scale factors used with annotative entities.
- Object Scale List
- Options
Object Scale List
Shows all the scales supported by the selected annotative objects.
- Add
- Adds annotation scale factors to the selected entities.
- Delete
- Removes annotation scales from the selected entities. Choose No in the Annotative field on the Properties panel to remove the annotative property.Note: This option does not work if there is just one scale factor attached to the entities.
Options
- List all scales for selected objects
- Lists all the scale factors.
- List scales common to all selected objects only
- Lists only the scale factor shared by the selected entities.Note: At least two entities must be selected.
