BLADE - BricsCAD LISP Advanced Development Environment dialog box
Opens via:
- BLADE command
- LSPSURF (Express Tools)
- VLISP command
The BLADE - BricsCAD LISP Advanced Development Environment dialog box allows you to edit and debug LISP applications.
The dialog box opens as an external application window, allowing it to remain open while you work on your drawings in BricsCAD. You can move and resize it with standard application window controls.
