Column Filter dialog box
Opens via: BOM Manager panel > Set column filter option
The Column Filter dialog box configures the column filter.
- Parameters
- Column name
- Always keep parent rows
Parameters
Defines the parameters to use in the column filter.
Column name
Displays the name of the column you put a filter on. Selects the type of filter that should be applied to this column and configures it.
- Always accepted
- All column values are accepted.
- Equal to
Value should be equal to the target one.
Note: Appears with numerical columns.
- Not equal to
Value should be not equal to the target one.
- Less than
Value should be less than the target one.
- Greater than
Value should be greater than the target one.
- Less than or equal to
Value should be less than or equal to the target one.
- Between
Value should be in the given range, both ends excluded.
- Not in range
Value should not be in the given range, both ends excluded.
- Exactly matches
The content of the column should exactly match the target one.
Note: Appears with columns containing text.
- Does not match
The content of the column should be different from the target one.
- Starts with
The content of the column should start with the given text.
- Does not start with
The content of the column should not start with the given text.
- Ends with
The content of the column should end with the given text.
- Does not end with
The content of the column should not end with the given text.
- Contains
The content of the column should contain the given text.
- Does not contain
The content of the column should not contain the given text.
- Matches pattern
The content of the column should match the given wildcard template.
- Does not match pattern
The content of the column should not match the given wildcard template.
- Included in
The content of the column should be in the given set of values.
Note: Appears with columns containing text and numerical columns.
- Not included in
The content of the column should not be in the given set of values.
