Edit Propulate Template dialog box
Opens via: PROPULATE command (Express Tools)
Allows you to save, load and edit a propulate template.
- File
- Edit
- Summary
- Custom Properties
- Block
File
Displays a menu to save or open new propulate template files:
- New...
- Clears all the fields of the current propulate template.
- Open...
- Opens the Select Propulate Template File dialog box to open a propulate template file.
- Save...
- Saves the current propulate template.
- Save As...
- Opens the Select Propulate Template File dialog box to save the propulate template file.
Edit
Displays a menu to insert lists or adjust the template fields:
- Insert Xref list
- Adds the @[XREFLIST] syntax at the current cursor location.
- Insert Font list
- Adds the @[FONTLIST] syntax at the current cursor location.
- Insert Image list
- Adds the @[IMAGELIST] syntax at the current cursor location.
- Insert Attribute
- Adds the selected value in the Block Attributes section at the current cursor location.
- Make active template
- Sets the currently edited template as the default template.
- Fill from Current Drawing
- Clears all edited fields and fills them with the Drawing Properties values from the current drawing.
Summary
Lists all standard elements of the propulate template.
- Title
- Specifies the title of your project.
- Subject
- Specifies the subject of your project.
- Author
- Specifies the author of your project.
- Keywords
- Keywords concerning your project.
- Comments
- Allows you to add comments to your projects.
- Hyperlink
- Links a hyperlink to your drawing.
- Last saved
- Specifies the person or institution that last saves the project.
- Revision
- Specifies the revision number.
Custom Properties
Allows you to add custom properties by defining the Name and the Value.
Block
Lists the values of block attributes from the current drawing.
