Format dialog box
Opens via:
- BOM Manager panel > Format option
- Data extraction Wizard - (Page 4 of 5) dialog box
The Format dialog box allows you to specify the format of text strings in the specified column of a BOM table or data extraction table.
Important: The layout of the Format dialog box depends on the selected item.
- Material class
- Format
- Format code
Material class
Displays the name of the selected item and a preview of the format type you set in the Format option.
Note: The name changes depending on the selected item.
Format
Specifies the desired format for the selected item from the list.
Format code
Displays the format code. The code changes depending on the format type you set for the selected item.
