Leica Connector dialog box
Opens via:
- LEICACONNECTOR command
- Civil Explorer panel > Civil tab > Connections > right-click Leica connection > Edit option
The Leica Connector dialog box provides a direct connection to a Leica Infinity database, allowing you to see changes made to imported Civil point and String objects, both in the drawing and in the Leica Infinity file.
When you run the LEICACONNECTOR command for the first time, you are informed that it is not possible to establish a connection to the Leica Web API.
Click the Download Leica Web API button to automatically download the installer for the Leica Web API application, then install it.
Run the LEICACONNECTOR command again. After establishing a connection to the Leica Web API, click the Browse button (
) to open the Import dialog box and select the Leica Infinity IPRJ file to import.
Connection name
Displays the connection name. The default name is the name of the imported Leica Infinity IPRJ file. Click the field to edit it.
Source file
Displays the path of the Leica Infinity IPRJ source file. Click the Browse button (
Lists the imported Leica Infinity objects.
- Objects
- Displays the Civil Points an Strings imported from the Leica Infinity IPRJ file.
- Unchanged
- Displays the numbers of the unmodified objects in the drawing.
- Modified
- Displays the numbers of the modified objects in the drawing.
- New
- Displays the numbers of the objects imported from Leica Infinity file in the drawing.
- Deleted in Infinity
- Displays the number of objects deleted from the Leica Infinity IPRJ file since the last load.
- Deleted Locally
- Displays the number of imported objects that have been deleted from the drawing.
