Load Multiline Styles dialog box
Opens via: Drawing Explorer dialog box (MLSTYLE command)
The Load Multiline Style dialog box allows you to load multiline styles from a multiline (*mln) file.
- File
- Multiline Style Name
- Description
File
Displays the Choose a Multiline Style File dialog box where you can select a multiline style file to open.
Displays the names of the available multiline style files in the drawing. You can select a multiline style file from this list.
Displays a description of the multiline style files, if available.
