Motion Path Animation dialog box
Opens via: ANIPATH command
The Motion Path Animation dialog box allows you to animate a camera moving along a path or panning in a 3D model and saves it to a movie file.
- Link camera to
- Link target to
- Animation settings
- Parameter
Link camera to
Defines the location of the camera by selecting a point or a path in the model space.
Note: After selecting a point or path, the option to name the entity is available.
- Point
- Links a camera to a static point in the drawing.
- Path
- Links a camera to a linear entity in the drawing.
Link target to
Defines the target point of the camera by selecting a point or path in the model space.
Note: If the camera is linked to a point, the target must be linked to a path. If the camera is linked to a path, the target should be linked to either a point or a path.
- Point
- Links the target to a static point in the drawing.
- Path
- Link the target to a linear entity in the drawing.
Animation settings
Allows to control the output of the movie file.
- Frame rate
- Defines the number of frames per second. When the frame rate is changed, the number of frames will be adjusted according to the duration.
- Number of frames
- Specifies the total number of frames in the movie. When the number of frames is changed, the duration will be changed accordingly.
- Duration
- Specifies the duration of the movie in seconds. When the duration is changed, the number of frames will be changed accordingly.
- Reverse
- Reverses the sequence of the frames.
- Corner deceleration
- Slows down the camera at corners in the animation path.
- Visual style
- Defines the visual style for the movie. Click the button and select a visual style in the list. All visual styles in the current drawing are available.
- Resolution
Sets the width x height resolution of the movie. Click the button to select a resolution.
Available resolutions are: 160x120, 320x240, 640x480, 800x600, 1024x768, 1280x1024, 1600x1024, 1920x1080, 1920x1200.
- Format
- Specifies the file format of the movie. Available formats are: avi, mpg and wmv.
Parameter
Allows to animate the change of a parameter.
- Animate
- Check the box to create realistic movies with moving mechanisms.
- Name
- Specify the name of the parameter.
- Start value
- Specifies a start value for the selected parameter.
- End value
- The parameter step is set to the Start-End range divided by the number of frames. On each frame, the parameter value should be incremented with the step.
