Navigate Settings dialog box
Opens via: NAVIGATE command
The Navigate Settings dialog box allows you to adjust the navigation settings in a drawing.
  1. Navigation mode
  2. Current drawing settings
  3. Registry settings
Navigation mode
Toggles between Walk and Fly modes:
  • Flight mode: permits movements in all three dimensions.
  • Walk mode: restricts movement to the xy-plane.
Sets the settings in the current drawing, and so will be different in other drawings.
Walk/Fly step size
Specifies the distance the view travels with each press of the key. The distance is measured in drawing units.
Steps per second
Specifies how quickly the view changes when a travel key is held down.
Registry settings
Settings which are saved with the registry, they will be the same in other drawings.
Rotation speed factor
Specifies how quickly the view rotates.
Keep horizon horizontal
When toggled on, the flight level is kept. This option is grayed-out for Walk mode.
