Publish details dialog box
Opens via: VIEWPLOTDETAILS command
The Publish details dialog box allows you to view the details about publish jobs, the errors that have occurred, or to cancel the ongoing publish jobs.
- Publish details specifics (1)
- Displays detailed information about completed publish jobs or the errors that have occurred. You can also monitor the ongoing publish jobs.Note: Check the count to ensure that all sheets were properly processed. The following counts are displayed:
- Sheets count: displays the total number of sheets specified for printing.
- Finished sheets: displays the number of sheets that were printed.
- Skipped sheets: displays the number of sheets that could not be printed.
- Cancelled sheets: displays the number of sheets that were cancelled.
- Renamed files: displays the number of renamed files. This means the sheet was printed but the name was modified to avoid name collision or disallowed characters.
- Refresh (2)
- Refreshes the list of published jobs to see the progress before the process is finished.
- Cancel Job (3)
- Stops the ongoing publish jobs.Note: It is only available when the publish process is in progress. When the process is completed or cancelled, the button becomes greyed out.
