Reassociate Entity Data dialog box
Opens via: REASSOCAPP command
The Reassociate Entity Data dialog box allows you to associate extended entity data with a specific application.
- Applications associated with Entity Data
 - Options
- Original application
 - Specifies the name of the original application.
- New application
 - Specifies the name of the new application. Entities will be reassociated with this application name.
Options
- Skip
 - Skips entities that already contains an item with the same name as the new application.
- Remove the existing application before reassociating
 - Removes the existing application before reassociating.
