Security Options dialog box
Opens via: SECURITYOPTIONS command
The Security Options dialog box allows you to set a password to protect your drawing from unauthorized access.
  1. Enter Password
  2. Crypt Provider
  3. Key Length
Enter Password
Specify a password by entering one or more characters.
Crypt Provider
Specifies the encryption level for drawing properties. Choose an encryption provider supplied by the operating system.
Key Length
Select a length for the encryption key. The longer the key, the higher the level of protection is, because it takes longer to break the encrypted password.
