Select Map Data dialog box
Opens via: MAPCONNECT command > Map Connect dialog box > Connect button
The Select Map Data dialog box specifies which layers to load from the WMS server and how they appear in the drawing.
Data layers list (1)
Lists the WMS imagery layers. You can select more than one layer.
Click Clear Selections to clear all selected layers at once.
Merged Layers (2)
Combines two or more selected WMS layers into one drawing layer.
Merged Layer's Name
Specifies the name for the merged layer.
Image Format (3)
Specifies the image format by choosing it from the drop-down list.
Transparent background (4)
Turns on or off a transparent background for the image.
Style (5)
Specifies the style by choosing it from the drop-down list.
Reference System (6)
Specifies the Coordinate Reference System (CRS) from the available layer coordinate reference systems in the drop-down list.
The definition of the supported Coordinate Reference Systems (CRS) is stored in the geodatabase.xml file, located in the folder specified by the ROAMABLEROOTPREFIX variable, such as C:\Users\%username%\AppData\Roaming\Bricsys\BricsCAD\V27x64\en_US\Support
Map Area (7)
Defines the rectangular area of the imagery layer that is loaded into the drawing. The area is set by the longitude and latitude values of two opposite corners.
Longitude
Specifies the longitude coordinates of the area to load.
Latitude
Specifies the latitude coordinates of the area to load.
Use Current View Extents
Sets the area to match the current view extents in the drawing. No tiles are loaded if the view is outside the layer.
Use Layer's Extents
Sets the area to the full extents of the selected layer. This is the default option.
Ground resolution
Specifies the ground resolution in meters per pixel. A lower value gives a sharper image and more tiles.
Estimated downloaded size
Displays the estimated size of the download, in megabytes.
Estimated number of tiles
Displays the estimated number of map tiles to download.
Add (8)
Adds the selected imagery layers to the drawing.
Note: Downloaded map tiles are saved as standard image files in the same folder as the drawing.
