Sheet View Properties dialog box
The Sheet View Properties dialog box allows you to view properties of a sheet view.
- Number
- Name
- Description
- DWG Handle
- DST Handle
- Category
Number
Specifies the number of the sheet view.
Name
Specifies the name of the sheet view.
Specifies a short description of the sheet view.
DWG Handle
Displays the .dwg file handle of the named view associated with the sheet view. It is read-only.
DST Handle
Displays the .dst file handle of the sheet view. It is read-only.
Category
Specifies the category of the sheet view.
