Show Entities with attached URLs dialog box
Opens via: SHOWURLS command (Express Tools)
The Show Entities with attached URLs dialog box shows the attached URLs in the drawing.
  1. Show URL
  2. Edit URL
  3. Replace URL
  4. Close
  5. Help
Show URL
Hides the dialog box and highlights the objects linked with the selected URL.
Edit
Allows you to edit the selected URL.
Replace
Allows you to replace the a URL by prompting the old one that has to be replaced and asking for a new one.
Close
Closes the dialog box.
Help
Redirects you to the BricsCAD® Help Center.
