Tool Image dialog box
Open via: Customize dialog box
The Tool Image dialog box allows you to specify the image of tools.
- Image
- List of tool images
Specifies the way to set the tool images.
- Builtin
- Specifies the tool image from one of the builtin tool images from the list.
- Bitmap File
- Specifies the tool image from a bitmap file.
- Resource
- Specifies the resource of the tool image.
- Abbreviation
- Specifies an abbreviation for the tool instead of an image.
- None
- No image or abbreviation is used for the tool.
List of tools
Displays a list of built in tool images when the Builtin option is selected.
