XDATA Editor dialog box
Opens via: XDEDIT command (Express Tools)
The XDATA Editor dialog box allows you to edit the extended entity data (xdata) associated with an entity.
- APP Name
- DXF Code
- DXF Value
- Pick <<
APP Name
Allows you to choose an application name from the list.
DXF Code
Allows you to change the XData DXF key code.
DXF Value
Allows you to specify a new DXF value.
Pick<<
Temporarily disables the XDATA Editor dialog box and allows you to pick a new value.
