Apple compatibility for BricsCAD
Apple introduces big changes with each major release of macOS. These result in a number of applications to break, including BricsCAD.
Note: The purpose of this article is to document the compatibility of new macOS versions. It does not list all old versions of macOS.
Support for Golden Gate (macOS 27)
- BricsCAD V27 is supported with Golden Gate.
- BricsCAD V26 is supported with Golden Gate.
Support for Tahoe (macOS 26)
- BricsCAD V27 is supported with Tahoe.
- BricsCAD V26 is supported with Tahoe.
Support for Sequoia (macOS 15)
- BricsCAD V27 is supported with Sequoia.
- BricsCAD V26 is supported with Sequoia.
- BricsCAD V25 is supported with Sequoia.
- BricsCAD V24 is supported with Sequoia.
Support for Sonoma (macOS 14)
- BricsCAD V27 is supported with Sonoma.
- BricsCAD V26 is supported with Sonoma.
- BricsCAD V25 is supported with Sonoma.
- BricsCAD V24 is supported with Sonoma.
Support for Ventura (macOS 13)
- BricsCAD V27 is supported with Ventura.
- BricsCAD V26 is supported with Ventura.
- BricsCAD V25 is supported with Ventura.
- BricsCAD V24 is supported with Ventura.
- BricsCAD V23 is supported with Ventura.
Support for Monterey (macOS 12)
- BricsCAD V26 is supported with Monterey.
- BricsCAD V25 is supported with Monterey.
- BricsCAD V24 is supported with Monterey.
- BricsCAD V23 is supported with Monterey.
- BricsCAD V22 is supported with Monterey.
- BricsCAD V21 is supported with Monterey.
Support for MAC hardware running Apple silicon
BricsCAD (Mac) V27 is distributed as a Universal Binary, which runs natively on both Intel (x86_64) and Apple Silicon (arm64) architectures.
