I can't send notifications about a document
When you want to send a notification and don't find the notification action for the document you're viewing, it's because the administrator in the project has disabled the option Can send notifications and view history for your role.
If you need to send a notification, you should contact the project administrator to change the settings of the role you're part of. See the Edit a role article for more information.
