Permissions required when copying and moving an item
Copy item
To copy an item from one folder to another, you must have Add permission on the folder to which you want to copy the item.
Move item
To move an item from one folder to another, you must have Delete permission on the folder from which you move the item and Add permission on the folder to which you want to move the item.
Important: Reservations are items that cannot be copied or moved.
