How to change the background color?
Do one of the following:
- On the command line, enter BKGCOLOR (Model space) and BKGCOLORPS (Paper space). Enter the value of the color you want to display (256 for black, 255 for white, ...).
- Open the Settings dialog and search for BKGCOLOR and BKGCOLORPS. In the drop-down list, select the new background color.
Note: BKGCOLOR applies to rendered visual styles only if PERSPECTIVE = OFF. The 2D Wireframe visual style always uses BKGCOLOR.
