How to solve customization issues for Places bar
Symptoms
After customizing the Places bar, the changes are not kept.
Note: This might happen on Windows 10 only.
Cause
It is probably caused by the default settings of Windows 10 that restrict access to the registry key.
Solution
- Make sure that BricsCAD is closed.
- You need to enable the customization of the Places bar from the Local Group Policy Editor.
To do that:
- Go to the Windows Start and type Edit group policy or open the Run window and type gpedit.msc.
The Local Group Policy Editor dialog box opens.
- On the left side of the dialog box, navigate to .
- Double-click on Items displayed in Places Bar to open the Items displayed in Places Bar dialog box.
- Change the state from Not configured to Enabled, then click Apply and OK.
- After that, follow the next steps:
- Right-click on the BricsCAD icon and select Run as administrator option.
- Make sure that the USESTANDARDOPENFILEDIALOG system variable is 0 (Off).
- Set your options for the Places bar: PLACESBARFOLDER1, PLACESBARFOLDER2, PLACESBARFOLDER3, and PLACESBARFOLDER4.
- Close BricsCAD and check again if the changes remain.
