Drawing Recovery Manager panel
- Run the DRAWINGRECOVERY command.
- Right-click a ribbon panel or toolbar and choose Drawing Recovery Manager from the Panels list.
The Drawing Recovery Manager panel displays a list of drawing files that can be recovered after a program or system failure.
After a program or system failure, the Drawing Recovery Manager panel appears automatically when needed and displays a list of all drawing files that were open, including DWG, DWT and DWS files. A new unsaved drawing can be found in the Drawing Recovery Manager panel if the corresponding autosave file (.sv$) was created while editing the new drawing.
- Backup Files
- Details
Backup Files
- DrawingFileName_recover.dwg
- DrawingFileName_a_b_nnnn.sv$
- DrawingFileName.dwg
- DrawingFileName.bak
Recovered drawings are added to the Recent Files list and removed from the Drawing Recovery Manager panel the next time the program is launched.
Right-click any item to display the context menu to access different actions depending on the selected item.
Folder:
- Open all drawings: opens all files from that folder.
- Remove: removes the folder from the panel without recovering the files.
Sv$ file:
- Open: opens the file.
- Save as .dwg: saves the file as a dwg file.
Dwg file:
- Open: opens the dwg file.
Details
Displays a few details for the selected file, such as the name, location and size of the file and the time it was last saved.
