Properties panel
The Properties panel offers a central location to access drawing, viewport, and entity properties.
It can be used in either Properties mode or Quick Select mode.
  1. Entities list
  2. Properties/Quick Select toggle
  3. Property Preview toggle
  4. Selection tools (Quick Select mode only)
  5. Properties list
Entities list
Displays the type and number of selected entities.
Note: The PROPOBJLIMIT system variable defines the limit of entities displayed in the Properties panel to improve performance. If the number of selected entities exceeds the limit, a warning message appears, and you are allowed to choose one of the options: Ignore limit or Change limit.
Switches between Properties and Quick Select mode.
Turns the PROPERTYPREVIEW setting on or off.
Selection tools
Creates a selection set based on properties. These tools are only available in Quick Select mode.
Properties list
Displays relevant property categories based on the current mode and selection set. You can expand and collapse categories by clicking on the + and – icons.
Properties mode
In Properties mode, the Properties panel enables you to view and modify drawing, viewport, and entity properties. Drawing and viewport properties are accessible when the current selection set is empty. Entity properties are accessible when the current selection set has at least one entity.
Entities list
When no entities are selected in Properties mode, the entities list shows No Selection and the properties list displays drawing and viewport properties.
When entities are selected in Properties mode, the entities list describes the type and number of entities in the selection set. You can filter the selection set by choosing a type of entity from the drop-down list. The types of entities in the selection set determine which properties are accessible.
Properties list (no selection set)
The drawing and viewport properties list, available when no entities are selected, displays General, View, and Misc properties.
General Properties
In Properties mode, when no entities are selected, General properties describe the current entity settings. View and modify current entity settings to specify the properties that apply to new entities as they are created. Changing the current entity settings in the Properties list has the same effect as changing the relevant system variables.
Color
Describes the current color (CECOLOR system variable). You can specify a new color from the drop-down list or choose Select color to access additional colors from the Color dialog box.
Layer
Describes the current layer (CLAYER system variable). You can specify a new layer from the drop-down list.
Linetype
Describes the current linetype (CELTYPE system variable). You can specify a new linetype from the drop-down list or choose Load to access additional linetypes from the Load Linetypes dialog box.
Linetype Scale
Describes the current linetype scale (CELTSCALE system variable). You can enter a new linetype scale.
Lineweight
Describes the current lineweight (CELWEIGHT system variable). You can specify a new lineweight from the drop-down list.
Transparency
Describes the current transparency level (CETRANSPARENCY system variable). You can specify a new transparency level from the drop-down list or enter a value.
Elevation
Describes the elevation relevant to the current UCS (ELEVATION system variable). You can enter a new elevation.
View Properties
When no entities are selected, View properties describe the current view and relevant view settings.
Camera
Describes the absolute coordinates of the camera in the current UCS, based on the cartesian coordinate system (X,Y,Z). These values automatically update when you orbit or change the viewpoint in other ways.
Target
Describes the absolute coordinates of the camera target in the current UCS, based on the cartesian coordinate system (X,Y,Z). These values automatically update when you orbit or change the viewpoint in other ways.
Perspective
Describes the current perspective setting (PERSPECTIVE system variable). You can turn Perspective on or off from the drop-down list.
Lens Length
Describes the current lens length (LENSLENGTH system variable). You can enter a new lens length.
Field of View
Describes the current angle for the field of view. You can enter a new angle for the field of view.
Height (read only)
Describes the height of the current view.
Width (read only)
Describes the width of the current view.
Clipping
Describes the clipping mode for the current view. You can specify a new clipping mode from the drop-down list. When clipping is turned on, parts of the view before the front clipping plane and/or behind the back clipping plane are hidden. This property is read only for layouts.
Front Plane
Describes the location of the front clipping plane. This property is only available when the Clipping property is turned on. This property is read only for layouts.
Back Plane
Describes the location of the back clipping plane. This property is only available when the Clipping property is turned on. This property is read only for layouts.
Visual Style
Describes the current visual style of the drawing. You can specify a new visual style from the drop-down list. This property is read only for layouts.
Misc Properties
When no entities are selected, Misc properties describe the current annotation scale and default lighting status.
Annotation Scale
Describes the current annotation scale (CANNOSCALE system variable). You can specify a new annotation scale from the drop-down list.
Default Lighting
Describes the default lighting status (DEFAULTLIGHTING system variable). You can turn Default Lighting on or off from the drop-down list.
Properties list (current selection set)
The Properties list only displays properties that are valid for all the selected or filtered entities. The more types of entities you select, the fewer properties are available on the Properties list. Filtering the entity list enables you to view and modify properties for multiple entities of the same type with minimal effort. When two or more entities are selected, the properties show their common values. Properties that differ between the selected entities are shown as *varies*.
Note: When area calculations take longer than three seconds, temporary yellowish node labeled "Computing..." is inserted in Properties panel. Even if you interrupt the calculation by pressing ESC in the Properties panel, the entities remain highlighted and their properties are available for the user.
Note: The mass properties of 3D solids and surfaces are visible in the Properties panel when multiple entities are selected.
All entities display General, 3D Visualization (Model space only), and Geometry properties. Additional properties may display for certain types of entities.
General Properties
In Properties mode, when entities are selected, General properties describe properties that are applied to the selected entities and are valid for almost any type of entity.
Handle (read only)
Describes the unique hexadecimal value by which the selected entity is identified in the DWG database.
Color
Describes the color of the selected entity. You can specify a new color from the drop-down list or choose Select color to access additional colors from the Color dialog box.
Layer
Describes the layer of the selected entity. You can specify a new layer from the drop-down list.
Linetype
Describes the linetype of the selected entity. You can specify a new linetype from the drop-down list or choose Load to access additional linetypes from the Load Linetypes dialog box.
Linetype Scale
Describes the linetype scale of the selected entity. You can enter a new linetype scale.
Plot Style
Describes the plot style of the selected entity. You can specify a new plot style from the drop-down list. Note that this property is only available when plot styles are enabled. Also see the PLOTSTYLE command
Lineweight
Describes the lineweight of the selected entity. You can specify a new lineweight from the drop-down list.
Transparency
Describes the transparency level of the selected entity. You can specify a new transparency level from the drop-down list or enter a value.
Hyperlink
Describes the URL of the selected entity. You can enter a new URL or choose the Browse button to access the Edit Hyperlink dialog box.
History
Enables you to undo editing operations for a selected entity. You can specify a previous step from the drop-down list to undo the entity back to one of the previous steps without undoing all the other commands and view operations that have been executed since. The History property only displays when the selection set includes only one entity.
Thickness
Describes the thickness of the selected entity. You can specify a new thickness by entering a value or selecting the picker icon and picking two points in the drawing.
3D Visualization Properties
Describes the materials assigned to the selected entities.
Material
Describes the current material of the selected entities. You can specify a new material from the drop-list.
Geometry Properties
Describes the geometric characteristics of the selected entities. These properties can vary for different types of entities.
Quick Select mode
In Quick Select mode, the Properties panel enables you to create a selection set based on entity properties. It includes selection tools and a operators.
Selection tools
Creates a selection set based on entity properties.
Apply to current selection set
This option is only valid if there’s an existing selection set. When enabled, the Entities list is limited to the entities in the selection set. When disabled, the Entities list includes all entities in the current viewport or layout.
Add to current selection set
Adds entities to the current selection set based on the entity types and property values you specify in the Entities and Properties lists. This option is unavailable when the Apply to current selection set is enabled since all possible entities are already included in the current selection set.
Remove from current selection set
Removes entities from the current selection set based on the entity types and property values you specify in the Entities and Properties lists. This option is unavailable when the Apply to current selection set is disabled since entities can only be removed from an existing selection set.
Add to new selection set
Creates a new selection set based on the entity types and property values you specify in the Entities and Properties lists.
Operators
A list of operators enables you to filter properties based on values. You can click on the current operator to display the list and change it to a different operator.
Select All
Does not filter the entity list based on the property.
Equals
Filters the entity list to include only those entities whose property equals the specified value.
Not Equal
Filters the entity list to include only those entities whose property does not equal the specified value.
Smaller
Filters the entity list to include only those entities whose property is less than the specified value.
Smaller Or Equal
Filters the entity list to include only those entities whose property is less than or equal to the specified value.
Greater
Filters the entity list to include only those entities whose property is greater than the specified value.
Greater or Equal
Filters the entity list to include only those entities whose property is greater than or equal to the specified value.
Properties list
Displays entity properties on which you can filter. The available properties depend on the types of entities in the drawing and whether the option to Apply to current selection set is enabled. General, 3D Visualization (Model space only), and Geometry properties are available for all entities. Additional properties may display for certain types of entities.
General Properties
Enables you to filter drawing entities based on their general properties.
Handle
Enables you to filter entities based on the unique hexadecimal value by which the entity is identified in the DWG database.
Color
Enables you to filter entities based on the color of the entity. You can specify a color from the drop-down list or choose Select color to access additional colors from the Color dialog box.
Layer
Enables you to filter entities based on the layer of the entity. You can specify a layer from the drop-down list.
Linetype
Enables you to filter entities based on the linetype of the entity. You can specify a linetype from the drop-down list or choose Load to access additional linetypes from the Load Linetypes dialog box.
Linetype Scale
Enables you to filter entities based on the linetype scale of the entity. You can enter a linetype scale.
Plot Style
Enables you to filter entities based on the plot style of the entity. You can specify a plot style from the drop-down list.
Note: This property is only available when plot styles are enabled.
Lineweight
Enables you to filter entities based on the lineweight of the entity. You can specify a lineweight from the drop-down list.
Transparency
Enables you to filter entities based on the transparency level of the entity. You can specify a transparency level from the drop-down list or enter a value.
Hyperlink
Enables you to filter entities based on the URL of the entity. You can enter a URL or choose the Browse button to access the Edit Hyperlink dialog box.
Thickness
Enables you to filter entities based on the thickness of the entity. You can specify a thickness by entering a value or selecting the picker icon and picking two points in the drawing.
Enables you to filter drawing entities based on their 3D visualization properties.
Material
Enables you to filter entities based on the material of the entity. You can specify a material from the drop-list.
Geometry Properties
Enables you to filter drawing entities based on their geometric properties. These properties can vary for different types of entities.
