ALIGNDIMENSIONONISOMETRIC system variable
Dimension alignment
Enables isometric dimensions. Dimensions are aligned to the geometry.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: | 1 |
| Possible values: |
Off (0): Disable isometric dimensions On (1): Enable isometric dimensions |
