AMSYMSCALE system variable
Mechanical2D annotation scaling
Controls the display of Mechanical2D symbols and text in Model Space.
Type:
Real
Saved in:
Drawing
Default value:
1.0
Note: The minimum value is 1.0E-100.
Related commands
  • AMDATUMID command
  • AMEDGESYM command
  • AMFCFRAME command
  • AMNOTE command
  • AMPARTLIST command
  • AMRESCALE command
  • AMSIMPLEWELD command
  • AMSURFSYM command
  • AMWELDSYM command
Related information
  • Model space and paper space
