ANTIALIASRENDER system variable
Anti-alias amount for render
Controls the smoothness of the output of the RENDER command.
For values higher than 1, an anti-aliased output is calculated, at a cost, this increases with bigger values.
BricsCAD only
Type: |
Short |
Saved in: |
Preference |
Range: |
1 to 5 |
Default value: |
2 |
Possible values: |
1: 1x1 (no anti-aliasing) 2: 2x2 3: 3x3 4: 4x4 5: 5x5 (maximum anti-aliasing) |
