ANTIALIASSCREEN system variable
Anti-alias amount for screen
Controls the smoothness of display output. When the value is greater than 1, the RedSdkLineSmoothing option is ignored.
For values greater than 1, an anti-aliased output is calculated. This calculation incurs a performance cost which increases with the value.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
1 to 5 |
| Default value: |
1 |
| Possible options: |
1: 1x1 (no anti-aliasing) 2: 2x2 3: 3x3 4: 4x4 5: 5x5 (maximum anti-aliasing) |
