APBOX system variable
Entity snap aperture box
Toggles the display of the Entity Snap aperture box. If the APBOX system variable is on, the entity Snap Aperture Box is added to the crosshairs when one or more entity snaps are active.
| Type: |
Boolean |
| Saved in: | Registry |
| Default value: | Off |
| Possible values: |
Off (0): Does not display the aperture box. On (1): Displays the aperture box. |
