AREAPREC system variable
Area precision
Specifies the number of decimal places displayed for areas when the area bit of PROPUNITS is on. If negative, LUPREC is used.
BricsCAD only
| Type: |
Short |
| Saved in: | Registry |
| Default value: |
-1 |
| Possible values: |
-1: Use LUPREC 0 1: 0.0 2: 0.00 3: 0.000 4: 0.0000 5: 0.00000 6: 0.000000 7: 0.0000000 8: 0.00000000 |
