AREAUNITS system variable
Area units
Controls a list of units used to display areas, if area properties are formatted with the PROPUNITS system variable. If empty, all areas match the drawing.
Note: The string contains a space-separated list of unit abbreviations.
BricsCAD only
| Type: | String |
| Saved in: | Registry |
| Default value: | in ft mi µm mm cm m km |
