account
translation
Bricsys Help Center
  2. System variable reference/
  3. A/
  4. AREAUNITS system variable/
BricsCAD
BricsCAD BIM
BricsCAD Mechanical
Communicator for BricsCAD
BricsCAD Shape
Dialog boxes
Panels
Command reference
_
2
3
A
On this page
Area units
Related commands
  • UNITS command
  • -UNITS command
Related variables
  • INSUNITS system variable
  • PROPUNITS system variable
Area units
Controls a list of units used to display areas, if area properties are formatted with the PROPUNITS system variable. If empty, all areas match the drawing.
Note: The string contains a space-separated list of unit abbreviations.
BricsCAD only
Type:
String
Saved in:
Registry
Default value:
in ft mi µm mm cm m km
Related commands
  • UNITS command
  • -UNITS command
Related variables
Products
BricsCAD® LiteBricsCAD® ProBricsCAD® BIMBricsCAD® MechanicalBricsCAD® UltimateCommunicator for BricsCAD®Bricsys® 24/7BricsCAD® ShapeApplication Catalog
Learn & Support
Product documentationForumBlogKnowledge baseWebinarsLearningDeveloper documentationRelease NotesContact support
About
About BricsysBecome a resellerCustomer StoriesAutoCAD® AlternativeEventsNewsroom
Buy
Store BricsCADStore 24/7MaintenanceFind a resellerStudents and Schools
My Account
My AccountManage LicensesMy support requestsInvoices and payments
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
AREAUNITS system variable - BricsCAD Lite & Pro | Bricsys Help Center
