ARRAYEDITSTATE system variable
Array edit state (Read Only)
Displays if an associative array's source entity is currently being edited.
Type:
Boolean
Saved in:
Not saved
Default value:
Off
Related commands
  • ARRAY command
  • -ARRAY command
  • ARRAYEDIT command
